Data Recording Fields
PbFoot
Post by PbFoot »
Is there a way to add and remove the data fields recorded?
It would be useful to see the tire pressure data on the exported CSV file.
I just set up the sensor so unsure how accurate/useful they are but even if the refresh rate is pretty low, the info would still be of value on the export.
Re: Data Recording Fields
Data fields recorded are not customizable. But there is an extended channel set beyond LapTimer standard channels documented in http://downloads.gps-laptimer.de/LapTim ... rogram.pdf
Tire data is missing for unknown reasons in CSV exports. They are available in HLPTRL exports only currently. But it is planned for the next feature release in Spring.
