Ignoring start trigger at low speeds
devildog1679
Post by devildog1679 »
In reading the changes to v15, I see that one of them is to ignore triggers at slow speeds to avoid false triggers. Is there a way to turn this feature off? I ask because I ran at Blackhawk farms this weekend in a High Speed Auto-X event. We basically line up at the starting line which is close to the start/stop trigger and do 1.5 laps the .5 being a cool down. I noticed that the timer was only recording the last half. I’m guessing that when I take off I’m not going fast enough so it ignores it but then picks it up when I pass it. Short of moving the trigger forward a bit is there anything else I can do?
Re: Ignoring start trigger at low speeds
This needs to be implemented as a new Expert Setting. I add this to either version 16 or 17.
In a configuration like yours, it makes probably sense to use a 'standing go' trigger on top of the stop/go trigger. Please check http://www.gps-laptimer.de/Trigger_Logik.html for more information on this.
devildog1679
Harry wrote:This needs to be implemented as a new Expert Setting. I add this to either version 16 or 17.
Thanks, uploaded the video and many on the Mustang forum were really impressed. Surprised so many don't know about this app. The best one that I can tell for a weekend track day.
Yes, but it is getting better all the time. :-) Thanks for your support!
