Will not trigger
bldn10
Will not trigger
Post by bldn10 »
I have HLT set as usual and it’s showing good gps but nothing happens when I pass start/finish. It never starts timing.
Even if I manually start and then walk past start/ finish nothing happens.
I am at the track now and need help ASAP!
Re: Will not trigger
This is the FAQ for you: viewtopic.php?f=39&t=2
Walking is usually not enough, LapTimer has a low speed trigger to work around false triggering.
In case you can't see an obvious problem when looking into the FAQ, please send a Contact mail using LapTimer's startup screen.
