I'd like to introduce you to our latest product that we've been testing for the past year or two - the 18Hz GPS_BT
We created this after seeing how current products either didn't behave properly or needed to be taped to a dashboard for proper reception.
The GPS_BT is small enough to be crammed in a cubby or zip-tied to a roll bar while the waterproof, magnetic antenna stays attached to the vehicle.
Currently the module is Android only, but we've worked hard and tested this on track to make sure the unit "just works". We're working to create the same experience for iOS users.
Please check us out at www.hazeeng.com and let us know if you have any questions!
-Andrew
Owner & CEO
