Can't connect to Apex Pro
rbpeirce
Post by rbpeirce »
It worked when I tested it at hme but at the track it just said searching. I am using the Kiwi device for OBD, and iPhone 8+ for HLT and the Apex pro, along with the app on the iPhone. I am operating with both the Apex Pro and the iPhone conn acted to power.
2012 Porsche Cayman R
2016 Audi A7
Re: Can't connect to Apex Pro
APEX Pro is a BT Low Energy device. I can't answer for sure, but most of these gadgets support one connection at a time only. So in case you see problems with a connect, check if you run some other app in background which accesses and blocks LapTimer.
rbpeirce
Post by rbpeirce »
Ah! The Apex Pro app is running in background. Thanks. I will test it by turning that off to see what happens and will post back tonight.
2016 Audi A7
You will need to kill it. :-)
rbpeirce
Post by rbpeirce »
Yes. Killing the Apex Pro app makes the sensor available to HLT. Unfortunately, Apex Pro data also is important. If I really need more sample speed I will add a separate GPS device. In the past I've used HLT more for the videos than for the data. I'm just getting into data so that is changing.
2016 Audi A7
