[SOLVED] Wrong language
rdl_1337
Post by rdl_1337 »
Few minor bugs present in both Pro and Trainer 15.0.2 versions:
-If you go to Lap List->Track->Test and then press setup icon, popup window doesn't have english translation (Espanol I think)
-Once you delete lap from Lap List it would be nice to update lap count under that track
-Scroll through Tracklist. Instead the one selected, the track in the middle expands to 3 lines
-LapList->Lap details->Data recording->Preview and LapList->Lap details->Results->Lap Time upper menu is hidden in landscape mode
Re: Wrong language
Thanks for sending this!
1+2 will be fixed in the next version. 3 is 'works as designed' on iPhone (as there is actually no selection), in Trainer, this effect should be turned off anyway. 4 is currently going through a redesign as I plan to support landscape in general. However, removing the navigation bar in the Data Analytics in landscape is done by purpose in LT v15. The navigation and status bar are using a lot of space in landscape.
