TONWON PRO VERSION
llan981
TONWON PRO VERSION
Post by llan981 »
My GoPoint BT1 finally died after 5 yers of use. Looking for replacement I see for TONWON, first one on your approved accessories list. Now, I see they have a pro version now. Is pro version approved and better? Overall, do you have a #1 preferred connector for HLT?
1. TONWON Car OBD2 WiFi Scanner, OBDii Diagnostic Scan Tool $19
https://www.amazon.com/TONWON-Scanner-D ... ast_sto_dp
2. TONWON OBD PRO $29
https://www.amazon.com/TONWON-Bluetooth ... 0352768445
Re: TONWON PRO VERSION
I have tested the Pro version from your second link. I don't know what exactly the difference is.
Please take care to select the on supporting BT4.0 (BTLE). I assume BT3 is BT SPP only, i.e. limited to Android. And I'd take a WiFi version only in case there is no other option. They are too complicated to use and block other WiFi connections.
