iOS v23.0.6 ApexPro Integration?
Dubbedown
Post by Dubbedown »
Just saw this feature listed in latest release. So are there any particular steps we need to follow when connecting to device? In addition to utilizing the Apex’s 10Hz GNSS, will the unit still function normally in terms of LED readout (assuming user is only running Lap Timer app)? If so would we need to first calibrate the Apex using its own app, close the app, and then start Lap Timer?
Re: iOS v23.0.6 ApexPro Integration?
Provided the APEX Pro app is killed, LapTimer will connect to the device automatically, trigger calibration automatically and will pull GPS positions from it at 10 Hz. The APEX’s standard operation will still work - including the LED signals. :-)
Dubbedown
Post by Dubbedown »
Harry wrote: Thu Aug 29, 2019 9:39 pm Provided the APEX Pro app is killed, LapTimer will connect to the device automatically, trigger calibration automatically and will pull GPS positions from it at 10 Hz. The APEX’s standard operation will still work - including the LED signals. :-)
Excellent! Looking forward to testing it out. Great feature addition!
