Telemetry status?
Charlienofun
Telemetry status?
Post by Charlienofun »
Hi! It seems the online telemetry is a little out of date (I get insecure script warnings then google API errors if I load the scripts anyway). I'm curious if this will be updated/fixed in the future? I was hoping to use this for my trackside laptop. If this feature is going away would it be possible to get this protocol documented so I could great my own display to be used trackside?
Re: Telemetry status?
The online view needs a fix, correct. I need to check what is going on.
Accessing the server directly is possible too, but most probably too complex to implement quickly. It utilizes a TCP socket connection and binary packages for exchange of data. You need to apply for the developer program to get access: viewtopic.php?f=11&t=4572
Charlienofun
Thanks! I was hoping it was something simple like a JSON POST :) I'll check that linked document and consider if it is worth bothering (maybe not if you are updating the existing map).
