VeePeak Custom BTLE OBD2 Adapter Troubleshooting
agentdax5
Post by agentdax5 »
Has anyone successfully used a VeePeak BTLE OBD2 adapter?
* Harry's LapTimer GP Edition
* VeePeak OBDCheck BTLE OBD2 adapter https://www.amazon.com/gp/product/B073X ... UTF8&psc=1
* iPhone 6S Plus running iOS 12.1.4
I have used this adapter with TrackAddict in the past but want to migrate over the LapTimer.
I sniffed the UUIDs using LightBlue and I can successfully get it connected as a Custom BTLE device but the update rate is too slow at 0.0Hz :lol:
I believe that my Read and/or Write UUIDs are wrong. I have tried basically every combination of UUIDs from sniffing via various apps with no luck. I also tried using the FFF* UUIDs with the BTLE base id as described in this post: viewtopic.php?f=6&t=4607
Screenshots of sniff results: https://imgur.com/a/pWK0zu9
Re: VeePeak Custom BTLE OBD2 Adapter Troubleshooting
Please post the Custom OBD Expert Settings you have set. I will check this against VEEPEAK’s interface. LapTimer v23 will come with predefined VEEPEAK Settings.
agentdax5
Post by agentdax5 »
Here are the combinations I have tried. All of them connect to the adapter but stop there.
Code: Select all
Peripheral Name : VEEPEAK
Service UUID    : 49535343-FE7D-4AE5-8FA9-9FAFD205E455
Read UUID       : 49535343-6DAA-4D02-ABF6-19569ACA69FE
Write UUID      : 49535343-ACA3-481C-91EC-D85E28A60318
Read UUID       : FFF1
Write UUID      : FFF2
Read UUID       : 0000FFF1-0000-1000-8000-00805F9B34FB
Write UUID      : 0000FFF2-0000-1000-8000-00805F9B34FB
Service UUID    : FFF0
Read UUID       : FFF1
Write UUID      : FFF2
Service UUID    : 0000FFF0-0000-1000-8000-00805F9B34FB
I know the correct UUIDs ;-) I wanted to see what you have entered in LapTimer. I’ll post the settings later when in office.
Code: Select all
LapTimer ‣ Administration ‣ Settings ‣ Expert Settings
    ‣ Custom OBD Adapter
        ‣ ELM327 Type ‣ Request/Reply
    ‣ Custom BTLE OBD Adapter
        ‣ Peripheral Name ‣ VEEPEAK
        ‣ Service UUID ‣ FFF0
        ‣ Read Characteristic UUID ‣ FFF1
        ‣ Write Characteristic UUID ‣ FFF2
agentdax5
Post by agentdax5 »
I tried those before but I just ran outside to try again and no luck.
Here are some screenshots: https://imgur.com/a/WdUNKTx
So it is a problem between car and adapter or the way LapTimer is accessing it. See Debugging OBD Connections in the FAQ section.
crazyxzer0
Post by crazyxzer0 »
I emailed you with information as well since I am having the same issue with the settings you posted.
As LapTimer v23 will come with native VEEPEAK support, I will not work on supporting it using the Custom OBD BTLE Expert Setting in v22. Thanks for your understanding, I want to concentrate on finalizing v23.
crazyxzer0
Thanks Harry!
Is Beta V23 working with VEEPEAK? I'm heading to a trackday 4/20 and would love to use it :)
