PosiMotion G-FI
AGT
PosiMotion G-FI
Post by AGT »
Will the PosiMotion G-FI GPS unit work without a jailbroken iPhone4 and will there be any compatibility issues with PLX KIWI WIFI?
Re: PosiMotion G-FI
The G-Fi GPS works with LapTimer on non-jailbroken devices. Wifi connections are not limited by iOS, so no jailbreak is necessary. As both the G-Fi and the KiwiWifi use Wifi to connect to the iPhone, only one of both can be used at the same time. Please note that Wifi connections drain your device's battery fast. You need to plan a power plug to use it for more than an hour or so. In case you did not buy a G-Fi already, I'd recommend to consider a TomTom car kit.
Greetings Harry
