Multiple Picture-in-Picture sources?
anthonymckay
Post by anthonymckay »
I know that HLT can't control multiple GoPros, but I'm wondering if I can manually start an additional GoPro, and import 2 overlaid videos? As in, I'd have a foward facing view from the phone's camera, a gopro pointing out the rear window, and an additional gopro pointing at my as the driver. Can I somehow import this 3rd video source as a second PiP like this:
Re: Multiple Picture-in-Picture sources?
Yes, record another video manually and transfer it to the phone. Select a lap from your session and select Add Video. This will add another PiP. Although this is not limited, more than 2 or 3 PiPs will look too cluttered, but informative. :-)
anthonymckay
Thank you, I just figured it out last night. The key bit of info missing here is that you must hit "Edit" in the upper right for the "Add Video" option to appear.
anthonymckay wrote:Thank you, I just figured it out last night. The key bit of info missing here is that you must hit "Edit" in the upper right for the "Add Video" option to appear.
Yes, that's what iOS user style guides asked for. :-) Probably a bit dated after 10 years. :-D
