Kiwi wifi question? - freezing
Bgibbs_1
Post by Bgibbs_1 »
is this what happens what when the connection drops? The connection seems fine but the OBD data in the log freezes quite frequently for like 5 seconds at a time, or is this the car not supplying updates? It is like the OBD freezes for 5 seconds and then starts goign again and is fine for a bit and then freezes again.
99 E36 M3
TIME SPEED_MPH LINEALG LATERALG HEIGHT_M HEADING_DEG WHEEL_SPEED_MPH RPM MAF THROTTLE GEAR
56:55.9 9.631253 0.42 -0.59 80 342.8 7.456454 711 10.36 0.56 2
56:57.0 10.066213 0.44 -0.6 80 339.2 10.56331 891 10.36 0.67 3
56:57.9 10.625447 0.44 -0.61 82 334.9 12.427424 1081 10.36 0.7 3
56:58.9 11.308956 0.41 -0.61 83 334.7 12.427424 1081 10.36 0.7 3
56:59.9 18.703273 0.37 -0.59 84 336.3 12.427424 1081 10.36 0.7 3
57:00.9 19.262507 0.35 -0.58 85 335.6 12.427424 1081 10.36 0.7 3
57:01.9 19.076096 0.32 -0.58 85 336.2 12.427424 1081 10.36 0.7 3
57:03.0 18.392587 0.3 -0.57 85 336.8 12.427424 1081 10.36 0.7 3
57:03.9 18.206176 0.29 -0.56 83 337.5 12.427424 1081 10.36 0.7 3
57:04.9 17.336256 0.29 -0.55 86 338.2 18.641136 1445 5.46 0.02 3
57:05.9 16.342062 0.29 -0.54 84 338.5 17.398393 1382 5.46 0.06 3
57:06.9 16.963433 0.29 -0.52 85 337.7 16.777022 1348 5.46 0.37 3
57:08.0 17.46053 0.07 -0.28 85 338.8 16.777022 1391 5.46 0.51 3
57:08.9 17.46053 -0.02 -0.19 85 338.2 18.019765 1493 18.83 0.01 3
Re: Kiwi wifi question? - freezing
A dropping line take longer to recover and is characterized by a broken connection between LapTimer and an OBD sensor. Do you have any other WLAN device in your car - or a bluetooth connection?
Bgibbs_1
Post by Bgibbs_1 »
so would there by missing data(zeros or blanks) while the connection was dropped or does it continue to store that last known reading?
no, nothing else in the car when this was created. I left my dual xgps150 at home today, but I plan on running that via bluetooth and and the kiwi over wifi.
Fyi - this is ebay non branded kiwi wifi.
Not sure without testing it. I assume you would see zeroed values. You can recognize dropping connections easily as all OBD displays will be removed from the display when it drops.
Bgibbs_1
Post by Bgibbs_1 »
Cool, I will check it out - also curious to see how it interacts with the dual xgps150.
thanks for your support Harry. HLT is truely a great app.
Brian
