Track "NAVAK" should be updated
mladjan
Post by mladjan »
There is a track NAVAK created by user rdl with old place for start/end. This old place is created before transponder equipment is installed, and we should change it.
Start/end should be at:
Latitude - Longitude:
44.837526,19.954793
Picture: http://cloud.mladjan.me/3M2t2838182l
Monika
Re: Track "NAVAK" should be updated
Post by Monika »
there is now a second configuration of NAVAK available:
In Harry’s LapTimer go to Admin -> Add-ons, update the list with button top right.
Afterwards search for NAVAK.
- Monika
Harry's LapTimer team
mladjan
Post by mladjan »
Hi Monika,
is possible to remove old track? It confuses app with these two available, last test on the track app was confused and my laps are missed.
The old configuration is in "Outdated POI Sets" - which is correct and allows users to access the Hall of Fame for old configurations.
Whenever you load a track set conflicting with a track set loaded already (e.g. when loading the new one and you used the old one before), LapTimer will prompt you and recommend to remove the old track. Usually, you should follow the recommendation to purge the old track set. In case you had not, please load the new one again and let LapTimer purge the old one this time.
