Overlay data not displaying
All Optrix VideoPro related discussions
Revolution
Post by Revolution »
Overlayed data and it worked it showed speed and lean angle but wasn't in sync friend told me how to sync but now all the data isn't showing just the track name and vehicle name and lap timer version in bottom left any help would be appreciated
Re: Overlay data not displaying
This is what you get before the lap actually overlaid starts. The sync point is probably wrong. Try to set the sync again, there is no reason it should not work.
Revolution
I finnaly got it to work after countless tries is there a basic sync procedure using hlt to trigger go pro for a session. Eg. Can you layout the steps I need to to sync the video cause if I do it at the start or end the overlay isn't sync'd.
I suggest you have a look into Video Documentation (www.gps-laptimer.de/documentation). It will give you a lot of background information and step-by-step instructions.
