Fix laps from racecapture in prevoius version
sirwin
Post by sirwin »
This is great: iOS and Android: Direction calculations for Autosport Labs RaceCapture device has been fixed. You should see a smooth driving direction movement now. The problem fixed did not only show wrong values, but led to missed triggers too. Please report back in case you are still seeing issues.
From the past weekend, I have some fused laps (3-4 laps counted as one), and some of incomplete (last lap) data.
I tried using the fix recently posted about setting new start stop points in the video to separate laps, but it did not work.
Is there a way to fix the problem? Apologies if this has been posted, I did not find the solution, if one exists.
Scott
Re: Fix laps from racecapture in prevoius version
You have used Lap List ‣ you multi lap ‣ Recalculate ‣ Verify Lap?
