Sharing data between devices
DrSlacker
Post by DrSlacker »
Is it possible to share track/lap data between devices on the fly?
I'm thinking specifically about autocross - 2 cars, each with an iPhone and a GPS. Can they share "track" data wirelessly to ensure their "lap" times can be compared accurately (ie to ensure they are using the same triggers)?
Better still, is there a way to wirelessly share "lap" data, so that during the event each driver can see (and compare) runs logged with both devices?
Re: Sharing data between devices
You can use the Track Certification mechanism to exchange track definitions. Goto
  • LapTimer ‣ Lap List ‣ your AX ‣ User Defined Track Set ‣ Certify
and change the TO mail address to your friend's email address. He/She can touch the .hpoil attachment to import your AX definition into his LapTimer installation.
Lap data can also be transferred directly between devices. It's a little complicated and not entirely intuitive, but it's worked pretty well for me. In Lap List, scroll to the bottom and select transfer. The instructions are there.
