GoPro Help
promethius
GoPro Help
Post by promethius »
Morning,
I am currently using my iPhone 7 and Kiwi3 OBD to record my track sessions. I was looking at purchasing a GoPro Hero 5 Session. However, I am a little confused on how to make these devices work together.
If I go with the GoPro, I use that device to record the track session, then do I use the iPhone as a connection device between the GoPro and the Kiwi3. If that is the case, the iPhone will only connect to one Bluetooth device at a time, so not sure how to make these devices work together. Any help, advise or information is greatly appreciated. Thanks.
Re: GoPro Help
Please find details on using external cams in "Fantastic Video Documentation" on www.gps-laptimer.de/documentation. The HERO 5 Session is not yet compatible with LapTimer, please consider either the HERO 4 Session or a HERO 5 Black. Cams not listed as compatible can be operated manually. This footage can be added manually to LapTimer too to add overlays. But it is more complicated. See the doc again.
