A track with two loops?
Mateusz
Post by Mateusz »
There is a track nearby that consists of two loops, done along different paths. It looks like this:
Is it possible to set up such a track in LapTimer at all? Special triggers would have to be used as the car passes some points twice (or even three times, in the middle), sometimes in opposing directions during the same run.
Mateusz
Re: A track with two loops?
This will work in case start / finish is set in a position passed only once (e.g. green in the top).
