Verify Lap doesn't change lap time
Does the Verify Lap function look at the Allow Low Speed setting?
At my last autocross, the starting line was very close to the staging line. I like to start recording before I actually start to avoid the delay in starting the camera. But in this case, a new lap wasn't triggered when crossing the line. After the fact, I found I had left Allow Low Speed on. I turned it off and used the Verify Lap function. Nothing changed. I even moved the starting line a little and it still wouldn't change the lap time. Is this expected behavior?
Re: Verify Lap doesn't change lap time
Yes, it should. Verify Lap uses the same detection engine as the one used in real time.
