Can't connect to GoPro
russ930
Post by russ930 »
I keep getting a message that a incorrect password was used. The lap timer won't connect to the GoPro. I have tried changing the password from the one used in the GoPro to the one for Harry's but it doesn't seem to make any difference.
Thanks in advance
Re: Can't connect to GoPro
In case LapTimer says the password is wrong, it is wrong ;-) Reset the GoPro and start over with the connection. But I know it is hard to maintain this connections. The GoPro app forces new connection making in special situations and it is very hard to keep track of the WiFi password configured here. Once you have established a new connection (with a new password), enter the password in LapTimer again. Take care you do not add trailing spaces and keep in mind the password is case-sensitive.
