Hill Climb support
nmartinez
Hill Climb support
Post by nmartinez »
does it have Hill Climb Lap Timer???
In the Hill Climb Championships needs:
- Start Mode: Movement (IPHONE sensor). With Movement, the logger will triggered by your initial acceleration at the start line.
- Stop Mode: Place the last split marker at the finish line.
Can you do this?
Re: Hill Climb support
LapTimer has this Hill Climb support already. What you want to do is defining a 'Standing Go' trigger in the valley, and a regular 'Stop' trigger at the finishing line. If you want, you can use the Autocross Assistant to do this. As you will hardly walk the finishing line, you simply drag the Stop trigger set anywhere near the starting point, using the Map View.
For Standing Go triggers, see the last section on this page: http://www.gps-laptimer.de/Trigger_Logik.html
