CSV export bug
pentavalle
CSV export bug
Post by pentavalle »
I just started motorbike season using LapTimer but when I exported session data in CSV format to use in RaceRender for overlay I found something strange.
Phone shows lap 3 time as 02:39.89, but in CSV file it's shown as 02:36.89, below there's an extract of exported data:
LapTimerDB.csv
157,03-APR-17,09:09:58.00,02:39.89,5.181600,3.219697,2,1,00:00.00,00:00.00,00:00.00,00:00.00,00:00.00,00:00.00,00:00.00,00:00.00,"",Me
LapTimerGPSRecDB.csv
128283,157,03-APR-17,07:12:37.49,156.890000,43.997597,11.371511,224.200000,139.311421,260.400000,854.330710,25.1,0,3,8,1.240000,3.7,5.181600,3.219697,0,0.16,-0.39,9.100000,0,0.000000,0.000000,0.000000,0.000000,0,0.000000,0.000000,0.000000,0.000000,0.000000
128284,158,03-APR-17,07:12:37.49,0.000000,43.997597,11.371511,224.200000,139.311421,260.400000,854.330710,25.1,0,3,8,1.240000,3.7,0.000000,0.000000,0,0.16,-0.39,9.100000,0,0.000000,0.000000,0.000000,0.000000,0,0.000000,0.000000,0.000000,0.000000,0.000000
Exported file was too large to upload in post, here's the link:
https://www.dropbox.com/s/0pyn3mpt7pkqn ... 7.zip?dl=0
Can you confirm the bug?
Re: CSV export bug
The CSV extract quoted shows 02:39.89 - the same value you say is shown on your phone: "Phone shows lap 3 time as 02:39.89, but..."? In case you see different values in LapTimer user interface and CSV, chances are very high different laps are compared. No bug.
pentavalle
Re: CSV export bug
Maybe I'm wrong but while LapTimerDB.csv shows 2.39.89 for lap 157, in LapTimerGPSRecDB.csv last data for that lap shows a TIME_LAP of 156.890000 seconds, so 2.36.89, that's why RaceRender shows a time of 3 seconds lower. When I render the overlay, timing for lap 155 and 156 is perfect, but video reach finish line of track 3 seconds later than indicated by GPS timing.
Re: CSV export bug
The TIME_LAP of the last fix should match the lap time. Sometimes it is +- 1 hundred second, but not more. In case a recording is incomplete, inconsistencies can happen. Please run a Check Data from Databases in this case. Many problems are fixed when running this routine.
pentavalle
Re: CSV export bug
Already tried many times but it shows there are no problems. It's the first time I have a problem like this.
Re: CSV export bug
Anyway, it is a data problem, no issue with the export. The export does no calculations but simply exports what is on the database.
