Problem with map display
BlackCat
Post by BlackCat »
When I look at a track set and then select the map display the satellite view appears showing the track but there are no overlays so POIs and triggers are not there! This was working perfectly last year so something has changed since last October. Any ideas?
I am using IOS and the Petrolhead version of Lap Timer with all the latest updates.
Re: Problem with map display
Try zooming in and out using a 2 fingers zoom gesture. LapTimer v20 always had some issues with missing POI displays. One of the problems fixed for LapTimer v21 appearing mid to end of April.
