Dual XGPS150 5Hz support
Hello everybody,
This is to inform you on the status of Dual XGPS150 support.
  1. Dual XGPS150 support is included since LapTimer version 14.0
  2. This initial support features direct NMEA access - resulting in extra accuracy, and additional GPS information like the Satellites View
  3. Since this initial release, I work with Dual to enable 5 Hz update rates
  4. LapTimer 14.4.1 enables 5 Hz mode for XGPS devices
However, there is an incompatibility between LapTimer 14.4.1 and XGPS150 devices with firmware 1.0.34 or less. This incompatibility blocks GPS updates by the XGPS, best recognized by "0.0 Hz" update rates. To work around this incompatibility, please disable direct NMEA access in Expert Settings: navigate to Settings - Expert Settings, turn 'Use GPS Accessories' off, close LapTimer using your iPhone's Home button. Finally restart LapTimer (either kill the process using the task bar, or simply restart your iPhone). This workaround allows using the XGPS. It will show up as 'Internal GPS', but it will be the XGPS150.
I have sent a bug fix release 14.4.2 to Apple today. It will be available in approximately 5 working days. This release will check the XGPS firmware version and enable 5 Hz for 1.1.0 and later only. It will be compatible to both firmware versions 1.0.34, and 1.1.0
The release date for XGPS150 firmware version 1.1.0 is not yet finalized. I will post updates here.
Sorry for any inconvenience,
evotell
Re: Dual XGPS150 support
Post by evotell »
I assume that this isn't a problem if I'm running the firmware Beta 1.12 from Duel?
Terry
2012 Caterham R400
2012 EVO X GSR
2001 Formula Arcobaleno
2008 Jeep Grand Cherokee (Diesel)
Mini Cooper S (Mini Miglia Race Car)
That will work both with 14.4.1 and with the upcoming 14.4.2. The whole 14.4.1 testing has been done with a firmware beta.
Hello everybody,
This is to inform you the planned release date for the Dual firmware is mid of February.
hms
Post by hms »
Harry wrote:Hello everybody,
Now you tell me !:)
Upgraded to 14.4.1 last night, and took me a couple of hours to get the Xgps working. Wanted to do a few laps around the houses at 1 hz to compare the results witht the 5hz upgrade.
h
Just received information from Dual they released the 5Hz firmware. :)
http://gps.dualav.com/firmware/xgps150
Celebrate and have fun! :D
shadowpuck
Post by shadowpuck »
great news, harry.
thank you for posting.
i've updated my Dual with the new firmware - that's a really simple process.
now, just have to wait for the driving season to start here; not until april!
evotell
Post by evotell »
Hi Harry
Any update from Dual regarding the firmware update?
Terry
2012 Caterham R400
2012 EVO X GSR
evotell wrote:Hi Harry
Terry
Just scroll up 2 posts and you get the status :-)
98 ZX14
Post by 98 ZX14 »
Just fyi....
I updated my XGPS last night. Had a pretty tough time with it.
I first tried to use my home desktop with Windows XP; then my work laptop with XP Pro. I installed the new USB driver and it could find the XGPS but it would not read and write to the unit. It would repeatedly get stuck in a writing loop going from 0 seconds to 1 minute then start over.
Finally got it to work with my daughters' laptop running Windows 7 with no problems.
