With Version 20 in Video Operations, you have option to set 1) no Iphone video, 2) Iphone, video, 3) main camera and gopro or 3) goPro only.
This year I was unable to get Iphone no video, goPro main, and Ipod pict-in-pict to work as I did in V19. I am hopefully, this can be rectified in V21.
MultiCam in V20.2.4
Re: MultiCam in V20.2.4
I will do some testing and I read correctly below, the multicam IPOD) will have wifi set to gopro and bluetooth will be a function of the multicam linking to the HLT (Ihome7) driven internally by the app. Right?
I guess this is the reference paragraph:
[iOS8.3 and later, MultiCam app] Since iOS8.3 (probably a minor version earlier), we face issues with establishing and maintaining a stable connection between LapTimer and the iOS MultiCam app. There are several problem reports with the iOS connectivity framework which should actually work with Bluetooth and/or WiFi device 2 device connections. Workaround: several reports suggest connections work better when both devices have WiFi and Bluetooth enabled and are connected to the same WiFi network. To realize the later, one can use the tethering mode of the device connected to the Internet. I plan to replace iOS's framework completely for a future major version. This is both to get back control and to allow mixed Android / iOS scenarios.
Re: MultiCam v21?
When will a new release of Multicam be released to support all the features of HLT Grand Priox Edition v21.0.6?
Just checking in when the multicam will be updated. Having a few upcoming events and would like to know if an update is coming out shortly. Thanks
