App freeze on track load
GT350LAD
Post by GT350LAD »
First noticed on IOS 10.0.2 - prepare race - load track either freezes when you select load track with window still up or immediately drops back to main "prepare race" screen and freezes. Manual kill and re-open, power cycle iPad and check database (no errors) = the same result.
I can go through add-ons and download track to make it active, but doing this with several tracks still does not allow the normal load track from "prepare race - load track"
Any suggestions?
Re: App freeze on track load
I assume you use an iPad? Please check the Known Issues FAQ here on the forum. The workaround is to use Add-one as you did already. NB: once a track is loaded, it will stay active. There is no need to load tracks every time you start.
GT350LAD
Post by GT350LAD »
Thank you, i did find the known issues FAQ finally. Keep up the good work!
