20hz GPS
Josh7owens
20hz GPS
Post by Josh7owens »
do you all suport a 20hz gps such as this one?
http://www.sxbluegps.com/sxblue-3-l-gps.html
ofcourse it would reqire jailbreaking the phone I'm just curius if anyon has used it or any other 20 hz gps unit
Re: 20hz GPS
Not sure. 20Hz produces a lot of data to be processed. Please note that high update rates come at the cost of lower accuracy - that's at least what I'm told by hardware manufacturers. I'm not sure 20Hz are required finally... In case you test it, I will support. But it needs to be on your own risk.
mkavney77
Re: 20hz GPS
Post by mkavney77 »
I'd be interested to see the outcome of this
