Reference Round
cdunkel
Reference Round
Post by cdunkel »
Hi
I don't know how to solve my issue:
I drive in l'Anneau du Rhin usually.
There we have two track configs which are also in the database, 3.0km and 3.7km they are officially called.
As reference round I choosed the fastest one.
Now, when I load and drive the 3.7km track it still takes the reference time of my fastest lap from the 3.0km config.
How can I config it so that it takes my 3.7km reference time?
Also is it somehow possible to define the fastest round of each day as reference? Or this might be a feature request?
Thank you
Re: Reference Round
Make sure you purge the track set for the configuration not used when driving. Or the other way round: when driving the 3.7 configuration, load it from Add-ons or Load Track and allow LapTimer to purge the other. This will make sure laps are recorded and are stored in the correct track section. Reference laps selected automatically (Best or Last) are always collected from laps in the same track configuration. In case LapTimer selects the wrong reference, make sure you have not mixed up your laps into wrong track groups. Go through them one by one using the Lap List and change the POI / Track sets from those sorted wrongly.
NB: LapTimer switches the current track when finishing a lap triggered by a stop trigger. This means the first lap may still be compared to a track set selected formerly. You can switch manually by selecting Status from the menu in Timer View.
Best of the day is not supported, only the best overall.
