GroPro 3+ Narrow
lee.pie
GroPro 3+ Narrow
Post by lee.pie »
Hi
I keep having trouble where i set my gopro to Narrow but on my next lap session it keep going back to Medium.
Any ideas?
Cheers
Lee
Re: GroPro 3+ Narrow
In Settings, switch the MultiCam Preset from Master to None. This will keep LapTimer to switch to what it thinks is the best setting for the action cam when recording for a master video.
lee.pie
Post by lee.pie »
Thanks Harry I'll give that a go.
I take I can still just use GoPro and not the iPhone cam?
Yes, the MultiCam Preset has two effects: it sets some recording defaults and it defines the default order for lap / video association.
1) None ‣ in case an external cam is controlled, it is turned on and off, but no video settings are changed; the external video defaults to master and an internally recorded video will be a picture in picture cam.
2) Master ‣ same as None, but sets video res to FullHD and the FoV to Medium.
3) PiP ‣ sets external cam to HD and FoV to Wide; the external video defaults to PiP while the internal will be the master
