Problem is the data give is so small I'm unable to read it at speed ... can you make it any larger?
How can you make the GPS/Speedo numbers larger?
All I need is the mph... we are using the vbox sport for offshore boat racing and the was told to down load Harrys Lap timer to read the unit and give me live data as I dont have a iPhone.
Re: How can you make the GPS/Speedo numbers larger?
[Moved to Feature Requests]
Speedo View (portrait only) has the largest speed display currently. An alternative will probably get available in v21. I plan to add a Dashboard View as a replacement for a standard dash.
