Settings for Kiwi 3 and F80 M3
Rick448
Post by Rick448 »
Can anyone share some settings which work well with an F80 M3? I've done a couple of videos and the throttle and revs are very irratic. It seems to connect at around 4hz. Also the throttle range seems well out even after going through the full range of operation.
Rick
Re: Settings for Kiwi 3 and F80 M3
Is the update rate stable or does it drop to 1 or 0 regularly? Throttle PIDs can be set in Expert Settings, there are several options. You need to test what works best for you. Please disconnect / reconnect the device to make sure the changed setting is in effect. Finally, you need to push down the throttle to the max to calibrate the 100 percent value. Before doing this, values will be too high. On track, this is no issue.
Rick448
Post by Rick448 »
Thanks Harry,
I'll try this and check the refresh rates on the Kiwi.
