Longer data recording than video
andrei.barbu
Post by andrei.barbu »
I am using Harry's Lap Timer Petrolhead Edition and I have a problem with syncing the video with the data recorded by the app.
Basically the video is a lot shorter than the data recorded, therefore syncing the end of the video with the end of the data recorded does't give me the right overlay. Is there a way to manually sync the video with the data recored?
Andrei
Romania
Re: Longer data recording than video
The lap's end needs to be part of the video to allow setting the sync point correctly. To workarounds: a) use a video editor to add a "black" range of frames to the end of the incomplete video and use LapTimer to set the sync point somewhere in the black... b) export the lap to .hlptrl and edit the sync information using a text editor. Import the .hlptrl file again and try to overlay it. I can't say if b works, but it is worth a try.
