Connection problem
janpe066
Connection problem
Post by janpe066 »
Hey!
I can not connect my GoPro Hero 4 with Harry Laptimer. The phone and the camera is connected so that I can communicate with the camera phone and the Go Pro app. But when I try to connect the devices in Harry's lap timer so it will not work. Any suggestions on what could be the problem?
I use:
Harrys Lap Timer V20.0.12
Go pro hero4
Samsung S5 with Android 5.0
Regards
Janne
Re: Connection problem
Make sure the GoPro app is killed, it will disturb operation while active in background. Furthermore, please keep in mind the H4 disables WiFi for power saving without notice when not used. So you may need to turn WiFi off and on again if you did not go into external video mode quickly.
