Enhanced VBO export
aaronpoweruser
Re: Enhanced VBO export
Post by aaronpoweruser »
Bumping this, would be nice to export fluid temps in vbo's for use in Track attack.
ereynold60
Post by ereynold60 »
ereynold60 wrote: Thu Nov 24, 2016 3:46 pm If you can also integrate any/all OBD data channels (when they exist for the laps being exported), that would be very helpful. From my previous testing, CT doesn't care what the channels are named; they are simply a stream of data points aligned to the GPS position. I was able to manually add channels for OBD wheel speed, RPM, throttle, gear, intake and coolant temps, etc. See my previous post and code sample above at:
viewtopic.php?f=10&t=3776#p19395
Ed
In the current v22, the VBO export includes RPM and Throttle from OBD, named as "EngineSpeed" and "GasPedalPosition", but it does not include wheel speed from OBD, nor temps. Gear, while derived by LT, would also be helpful in a VBO export... enabling these data points to be examined using CircuitTools.
Are there plans to add these data stream to VBO export ?
Ed
Counted as an upvote ;-)
ereynold60
For me, actual "Wheel Speed" from OBD is the most critical. Gear is next... temps are a nice to have.
gremlin
Post by gremlin »
I'd really like to see the Gear # exported as well please! I've been using TrackAttack and really would like it to show me gear.
aaronpoweruser
Was this ever added?
