I have a full version of laptimer on my Android (Sony Xperia Z3 compact), and everything was great until yesterdays session. I had it in another circuit, loaded the track, and laptimer worked, I even see that the lap count in "Analysis" section is more than before the session, but as soon as I want to open Analysis section, laptimer crashes and shuts down.
All the other features work - no problem.
Please help, I have race this weekend. Need the data and info.
Can't open analysis, crashes
Re: Can't open analysis, crashes
I think I see the problem in the crash logs. Try to transition to Lap List using the drawer list (top left button showing lines). In case this works, go through you track list and check if one of the Track Sets loaded / defined have more than 8 split triggers. Remove that track set for now and you should be able to open the Analysis tile again. I will submit version 20.0.4 of LapTimer later today. It should fix that item completely.
It totally helped. I can access the track and lap list like that. I cant delete this track for now, I need that info, but as I can access it, everything is fine.
Thank you for the quick and helpfull answer, this laptimwr is the best you can get by a mile!
Will wait for the update.
Good luck!
Good luck!
Congratulations Harry, what efficient and fast support!
20.0.4 is online, please let me know how pressing Analysis works now.
Just updated and checked, everything works perfectly. Again, thank you Harry for such a fast support.
Perfect job!
Perfect job!
