About times in hall of fame
Skylinehead
Post by Skylinehead »
Hi, I accidentally put several same laps in hall of fame, is there a way to delete them? Also, I noticed that not all my laps are in hall of fame, so I'm wondering how does the hall work? Thanks.
Re: About times in hall of fame
Duplicates are purged from time to time, I need to trigger this manually...
In case a lap time does not appear in the HoF, there are several possible reasons: online racing has been disabled when recording the lap (see LapTimer's Settings), or the lap recorded does not qualify for addition. The later happens if the track set is not certified (changed) or if the distance recorded does not match the design length of the track set. This is done to filter shortcut or wrong configurations.
