GoPoint BT1 on 2014 Corvette Stingray, gear indicator
RKinger
Post by RKinger »
My question is simply, is it possible for HLT to use the vehicle's gear indicator which may be available via the GoPoint BT1 OBD2 interface verses the "calculated" gear based upon gear ratios, tire size, etc.?
My vehicle is a stock 2014 Chevrolet Corvette Stingray Z51 M7.
Thanks in advance for any advice.
Re: GoPoint BT1 on 2014 Corvette Stingray, gear indicator
No, gear is no standard OBD parameter (like most data on the bus) and not available without adding model/make/year specific tweaks (custom PIDs).
