LapTimer did not work for me on iPhone 5s
TrackMan
Post by TrackMan »
I used LapTimer the first time at Lime Rock Park. Track, driver and car everything is defined with good GPS connection from external GPS and the application says everything is fine and good to go but it never started by itself, means after the session the system was still in "ready mode" but no data. I am not blaming the application and I guess I do something wrong but I just can't figure out what. Any suggestions?
Regards
Christian
Re: LapTimer did not work for me on iPhone 5s
Most potential issues are covered by LapTimer's Heath Check shown e.g. in the top of Timer View. In case you see a red alert, touch it to get information on the details and what to do to fix it. Most other issues are around the correct track set loaded (e.g. counter clockwise vs. clockwise) and degrading GPS accuracy. The later is a common pattern for drivers putting the smartphone into their pockets or turn off the screen. LapTimer will switch the health status immediately, but one will not see it...
RaymondAbel
Post by RaymondAbel »
allo
My HLP did not work at all last but an other one did.
I read " turn off the screen" In my case, The phone I use is set by my cie so it as an auto-lock after max 5 min. Knowing it take more then 5 minutes getting ready: get Motorcycle gear on, remove tires warmer etc May it explaine why it never work?
LapTimer needs to be active / in foreground while driving. In case it locks / the phone goes to sleep, it will disconnect from all sensors and sleep too.
LapTimer keeps the phone from going to sleep while in any Timer View. You see a small lock icon in the bottom right when the phone is not allowed to go to sleep. You can dim the screen to save battery - but keep it on please.
