GoPro not started by HLT (iPhone6)
ptrskycam
Post by ptrskycam »
HLT recognizes my GoPro 3+ Silver, but only starts the timer and the iPhone camera (doesn't start the GoPro). Any ideas? By recognize I mean wifi is on, connected to the GoPro, and the top right of the HLT screen shows the GoPro icon.
Re: GoPro not started by HLT (iPhone6)
LapTimer displays the cam when it can locate it. When starting recording, it sends a command - which seems to fail. The usual issue for HERO3/3+ cams is a wrong password. You need to set the password in LapTimer's settings precisely in the way it is set for the WiFi. Take care for upper / lower case. In case you cannot make it working, reset the WiFi connection an create a new WiFi / password. Enter that password in LapTimer now you are sure which one to use.
ptrskycam
Post by ptrskycam »
Thanks Harry. That did the trick. Now I just have to figure out how to use some of these features!
