Need a second layout of existing track
clausm
Post by clausm »
Hello
I am going to "Jyllandsringen", an existing track.
Originally 1.475 metres - but extended to 2.300 metres. It is the 2.300 meter edition that exists in the library.
Can you help me create a "Jyllandsringen Short/Original", as the 1.475 meter is still in use (And that is the layout I will be driving). I believe it will require a bit of editing on the sectors. I will not need it for a couple of months, so there is no urgency in creating it.
Here you see the track. The dotted line is the extension to 2.300 meters. The solid line is the original layout of 1.475 metres.
Thank you very much.
Regards,
Claus
Re: Need a second layout of existing track
We'll add it and come back.
Monika
Post by Monika »
there is now a second configuration available: Jylland Ringen Short
Please check it out via 'add-ons', update the list via the button at the top right corner and search e.g. for ‚Jylland‘.
Regards,
Monika
