Entering Torque details
Henry_Au
Post by Henry_Au »
I can not seem to be getting the Torque correct.
My car data are:
Displacement cc 1991
Bore x stroke mm 83.0 x 92.0
Rated output kW/hp 265/360 at 6000 rpm
Rated torque Nm 450 at 2250-5000 rpm
Compression ratio 8.6 : 1
I entered the following in Laptimer:
Max Torque 450Nm @ 2250 rpm
Max Power 265KW @ 6000 rpm
Max RPM 6500 rpm
Shift Flash 90%
Vol. Efficiency 75%
All other measurements entered correctly.
Do I need to change any of the values above
Thanks again.. the most helpful app developer ever.. :)
Re: Entering Torque details
Torque calculation requires the following items available / set:
MAF (OBD), engine type (Vehicle Details), intake type (Vehicle Details), RPM (OBD)
Henry_Au
Post by Henry_Au »
Maf, rpm all coming smoothly now from automatic.
Are the values above correct?
Yes, I think so. Have you selected engine and intake type?
Henry_Au
Post by Henry_Au »
Yes all accurate.. May be it is only street drive the torque not showing well..
