G-meter out of sync
Chad-1stgen
G-meter out of sync
Post by Chad-1stgen »
I've been having random sync issues when using HLT lately. A few times now when using manual start and stops to record autocross sessions the g-meter gets out of sync with the video and speed. In the video I uploaded below the speedometer is accurate but the g-meter is delayed. Any idea what causes this and how to fix it?
https://youtu.be/ffgRIoLlVuM
Re: G-meter out of sync
I discovered some sync issue when recording manually. The delay applied is not reflected correctly. This mean for v19, you need to manually adjust the video sync point by the delay - which is 1s usually.
Please do not use the speedo for syncing, speed reported by GPS is always late.
PS Will be fixed in v20
