When attempting to overlay laps, HLT starts processing as usual, then times out and closes the app down after about 30-50% processed. Have tried restarting phone, closing down ALL over open apps, trying one lap at a time.
Phone is iPhone 6s
Master video is gopro hero 4 video synced from iTunes
PIP is front facing camera
John
HLT Timing out when overlaying?
Re: HLT Timing out when overlaying?
Hi John,
The PiP feature generates an incredible memory requirement since iOS9. I need to add a workaround to make it work again. I have been able to overlay a 3 minute lap using a 6S, more will hardly be possible currently. To work around, please check the Known Problems FAQ (viewtopic.php?f=39&t=1693) and follow the link for the workaround.
Thank you Harry!
I went into iTunes and renamed the files (.mov2) and synced the 6s. Now I am not clear on what do to next? Do I go into Lap list>select a lap (that is already assoc with the master gopro video)>edit to remove pip video>click overlay?
Just keep the PiP now showing Offline or No Video. Press Overlay to start the overlay without a PiP. Ignore the warning the PiP video is missing.
