Brake Trigger for .vbo export
bazza_c
Post by bazza_c »
Can you create an option whereby pressing the 'split' button creates the equivalent of a brake trigger marker in the .vbo file? that is because when i export to iml, i want to see the actual location of the split trigger in both the google earth and racelogic tools software.
regards
Baard
Re: Brake Trigger for .vbo export
RL uses its own trigger / track definitions. It considers vbo files to be data streams, not laps / sectors. This is decided on during import. Due to the difference in track definitions, times will mostly be off a bit.
