Autocross track creation wizard closes before finish line?
Posted: Tue Sep 15, 2015 5:57 pm
				I was trying to create a new Autocross course but was having some difficulties. I would go Prepare Race -> Autocross -> Set the Standing Start. Then I would start walking the autocross course, the distance in meters would increment, but before I got to the finish line the autocross wizard popup would be gone and I would be back at the Prepare Race screen. Something was causing the autocross track creation wizard to close and I am not 100% sure why.
I did notice that if I pressed the screen lock button on my phone this would cause the BT signal to the XGPS160 to disconnect, so I was walking around with the screen on. (I had the XGPS160 in my pocket while walking the course). I also notice that if you rotate the phone from portrait to landscape the wizard closes, maybe this was inadvertently happening. Or maybe the phone screen was auto locking? I thought it was possible to lock the phone screen, put the phone in your pocket, walk the course, then take the phone out at the finish line and set the finish point, maybe not?
The autocross course physically takes place on a racetrack that I also have loaded, could POIs or triggers from the racetrack be interfering with the autocross course creation?
Maybe I am misunderstanding the usage here, I found this post and will try walking straight from the start to the finsh next time:
http://www.gps-laptimer-forum.de/viewto ... 003#p15336
Specs:
HLP GP v19.0.17
Android 5.0 on Samsung S5
Dual XGPS160
Specs:
HLP GP v19.0.17
Dual XGPS160
