XGPS160 Question
captaindave
XGPS160 Question
Post by captaindave »
I used a n XGPS160 for the first time with your lap timer and everything seemed to work OK except the g-gotce readings in the traction circle are centered to the left side of the circle Is there any way to correct this?
CaptainDave
Re: XGPS160 Question
Recording of acceleration is not done using the XGPS160 but the internal acceleration sensor. Please take care you mount the device in one of the orientations / positions shown in Quick Reference / illustration #4.
To correct acceleration "after the fact", you can indeed let LapTimer calculate acceleration from GPS. To do this, select a lap from Lap List, scroll down to Data Recordings, select Re-Calculate and Acceleration.
