Hall of Fame
Giorgos 997 turbo
Hall of Fame
Post by Giorgos 997 turbo »
Hello ,
I use the Grand Prix edition & android Galaxy S5
Can anyone tell me how I can add all my laps to the Hall of Fame for Athens Circuit???
when i push the button Hall of Fame to a specific Lap I see ''Scheduled for transmission to Hall of Fame' but nothing happens next.
Thank you
Re: Hall of Fame
That is standard behavior, pressing Hall of Fame queues a lap time submission and will operate in background. Once this is successful, you should be able to see you lap time in the track's HoF.
In case it does not appear, there are several possible reasons: the track set the lap has need recorded for is not certified (user set or changed); the lap is consider invalid by the server (distance doesn't match standard distance etc); or the server connection cannot be made (you should see the network gadget turn solid shortly after submitting the lap, with some green and blue blinks. In case you see an exclamation mark, the server cannot be contacted) etc.
As long as you haven't disabled Publishing in LapTimer Settings, laps are submitted automatically to the HoF - just in case.
