GoPoint BT1 - how to log ignition time advance?
the_jeby
Post by the_jeby »
I'm using a GoPoint BT1 connected to an iPhone 5S. Everything works ok, but when I export session to CVS i see only few PIDs are logged:
RPM, MAF, WHEEL_SPEED_KPH, WHEEL_SPEED_MPH, THROTTLE, GEAR, FUEL, COOLANT_CELSIUS, OIL_CELSIUS, IAT_CELSIUS, MAP
I'm using the same adapter with same phone and Dashcommand, and it's able to log a lot more PIDs, including short time/long time fuel trims and ignition time advance.
Is it possible to the same on Harry's gps LapTimer?
Re: GoPoint BT1 - how to log ignition time advance?
Please keep in mind that each PID you log reduces the overall update rate engine data is coming in. This is the reason LapTimer focusses on values used within the app and with a benefit for most racers. Once it is getting very special, please use an OBD logger app.
