Drag Race: 0-100, 0-200
argonid
Post by argonid »
Hello Harry,
I would find it amazing if there is for example a Race mode, where I can set "0-100km/h" or "0-200km/h" or "0-1000m".
Is there any intention of you to do this?
I mean that Laptimer starts to count at launch and counts the seconds till the end of the race mode.
BR,
argonid
Re: Drag Race: 0-100, 0-200
[Moved to Feature Requests]
argonid
Post by argonid »
I have now seen that a similar topic is: "100-200 kph".
http://www.gps-laptimer-forum.de/viewto ... f=10&t=250
The post if from 2011. do you think this will be realistic in the next months?
BR,
argonid
It is on my list but still not scheduled. I have too many items to prioritize for the next release 19.1 - sorry.
GlnkNL
Post by GlnkNL »
This would be awesome
fea30boy
Post by fea30boy »
1/4 mile time would be great too! I would like to retire my Racelogic PBox
I plan to add a small feature in LapTimer v19. It will show the distance from start when using the AX assistant. This means you can use the AX assistant to set up quarter miles (and other distances). It is not super convenient but will at last bridge he time until a complete performance testing engine is added...
GlnkNL
Post by GlnkNL »
There was an app called Dynolicious that doesn't work anymore with the latest iOS (was never updated). It worked quite well except there was no control over the start function. The timing started as soon as the accelerometer detected any movement, and this was very very sensitive. You could set it off by revving, really :D. But something like that would be nice for HLT. It also drew a result graph showing the estimated power. That caluclation was done with a few variables that you had to enter; vehicle curb weight, driver weight, current fuel level etc. Might not be super accurate but its fun :)
Here I do a test with it:
[youtube]http://www.youtube.com/watch?v=-xM57vxB4gw[/youtube]
I'm pretty sure I've said this before...you can simply do your 100-200 runs while you manually started HLT. Do as many runs as you like and stop HLT manually. Then export that log to VBO and use Racelogics Performance Tools to scan that file for 100-200 runs, software is available for free:
http://www.vboxmotorsport.co.uk/downloa ... _Setup.zip
